Ga door naar hoofdinhoud
Toshiba Satellite A65-S126 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite A65-S126 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Keyboard Replacement, Upper Assembly: stap 3, afbeelding 1 van 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite A65-S126 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 1
    • Using a screw driver for assistance, pop open the plastic cover and snap it off of the hinges. Repeat on the opposite side.
  10. Toshiba Satellite A65-S126 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the two 3mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Slide keyboard out and away from the upper assembly.
Conclusie
Aditya Varkhedi
104 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-8, Forte Fall 2013 Lid van Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 743
