Ga door naar hoofdinhoud
Toshiba Satellite A305-S6848 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite A305-S6848 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite A305-S6848 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Conclusie
Joshua E Hong
449 Reputatie
4 handleidingen geschreven
Baylor, Team S8-G1, Johnson Fall 2017 Lid van Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 573
