Ga door naar hoofdinhoud
Toshiba Satellite A305-S6848 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
  2. Toshiba Satellite A305-S6848 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove plastic covering.
    • Pull up the silver tab to remove the hard drive from the slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua E Hong
449 Reputatie
4 handleidingen geschreven
Baylor, Team S8-G1, Johnson Fall 2017 Lid van Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Leden
12 handleidingen geschreven
Één opmerking
Note: There are two hard drives in this machine. One has a single screw holding it in place within the compartment, and is very straightforward. The other has two screws. After removing the latter, the drive compartment pulls out, sliding over the now empty screw holes.
Kim McCoy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 1,014
