Ga door naar hoofdinhoud
Toshiba Satellite A215-S7425 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: stap 3, afbeelding 1 van 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite A215-S7425 RAM Replacement: stap 5, afbeelding 2 van 2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite A215-S7425 RAM Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite A215-S7425 RAM Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite A215-S7425 RAM Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite A215-S7425 RAM Replacement: stap 7, afbeelding 3 van 3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Conclusie
Marianne
647 Reputatie
6 handleidingen geschreven
Pasco Hernando, Team 5-2, Prince Fall 2014 Lid van Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 270
