Ga door naar hoofdinhoud
Toshiba Satellite A215-S7425 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Slide case away from hard drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Marianne
647 Reputatie
6 handleidingen geschreven
Pasco Hernando, Team 5-2, Prince Fall 2014 Lid van Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 26
Altijd: 918
