Ga door naar hoofdinhoud
Toshiba Satellite A215-S4757 Display Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 3, afbeelding 3 van 3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 4, afbeelding 2 van 2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite A215-S4757 Display Screen Replacement: stap 5, afbeelding 3 van 3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Brown
409 Reputatie
3 handleidingen geschreven
Texas Tech, Team 12-2, Bennett Fall 2016 Lid van Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 341
