Ga door naar hoofdinhoud
Toshiba Satellite A215-S4757 Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite A215-S4757 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before removing anything on your Toshiba Satellite, make sure your computer is turned off, and your power adapter is not plugged in.
  2. Toshiba Satellite A215-S4757 Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn your Satellite over and locate your battery.
    • Locate the battery clips.
    • With your thumb and pointer fingers slide them outward at the same time, and hold.
  3. Toshiba Satellite A215-S4757 Battery Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite A215-S4757 Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the battery out of its socket until completely removed and release the clips.
    • Your battery is now removed from your computer.
Conclusie
Jacob Brown
409 Reputatie
3 handleidingen geschreven
Texas Tech, Team 12-2, Bennett Fall 2016 Lid van Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 297
