Ga door naar hoofdinhoud
Toshiba Satellite A215 S4697 Optical Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  4. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  5. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 5, afbeelding 3 van 3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  6. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 6, afbeelding 2 van 2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  7. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 7, afbeelding 2 van 2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  8. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 8, afbeelding 3 van 3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  9. Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: stap 9, afbeelding 3 van 3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Mike Dongyub Ryu
566 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-12, Maness Spring 2013 Lid van Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 4,356
