Inleiding
In this guide you will learn how to remove the RAM. In the case of a broken or unresponsive RAM a replacement may be required. Before begining this guide you should have all required tools that are listed.
Wat je nodig hebt
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
In order to reassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
