Inleiding
In this guide, you will learn in a step by step process how to remove an optical drive in your Toshiba Satellite. This guide does require some tool use. Follow each step according to the bullets provided.
Wat je nodig hebt
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
Use a PH0 screwdriver to remove the screw holding the optical drive in place.
Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
The optical drive will then slide out.
Één andere persoon heeft deze handleiding voltooid.
