Ga door naar hoofdinhoud
Toshiba Satellite A210 Optical Disc Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A210 Optical Disc Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: stap 3, afbeelding 1 van 2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: stap 3, afbeelding 2 van 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite A210 Optical Disc Drive Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite A210 Optical Disc Drive Replacement: stap 4, afbeelding 3 van 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: stap 5, afbeelding 1 van 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: stap 5, afbeelding 2 van 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: stap 5, afbeelding 3 van 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bret Wilson
274 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-5, Regan Spring 2013 Lid van Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Leden
18 handleidingen geschreven
Één opmerking
Question : if i this will my screen start working ng again
jessica johnson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,603
