Ga door naar hoofdinhoud
Toshiba Satellite A210 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A210 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A210 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite A210 Keyboard Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite A210 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite A210 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Conclusie
Youlen
40 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-5, Regan Spring 2013 Lid van Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Leden
18 handleidingen geschreven
Één opmerking
very useful. THANKS
ANDREAS - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,585
