Inleiding
In this guide you will learn how to remove a keyboard safely. Before you begin this guide you should have all required materials and tools necessary to properly remove the keyboard.
Onderdelen
Geen onderdelen nodig.
  1. Unplug the AC adapter and all other auxiliary components from the laptop. Slide the battery lock tab away from the center of the laptop to unlock the battery.
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Slide the battery release tab away from the center of the laptop and hold it. Lifting from the small notch between the two tabs, pull the battery out of the laptop.
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Unscrew the 4 highlighted screws with a PH1 screwdriver.
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  5. Orient the laptop so that the screen is open and facing you. Slide the plastic opening tool underneath the top edge of the black plastic insert. Pull it off and set aside.
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  6. Remove the 2 PH1 screws. Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  7. Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Youlen
19 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-5, Regan Spring 2013 Lid van Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Leden
6 handleidingen geschreven
Één commentaar
very useful. THANKS
ANDREAS - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 6
Altijd: 2,161
