Inleiding
Whether it is time to upgrade or replace the optical drive, this guide will show the user how to remove the drive from the laptop.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Locate the two sliding locks indicated in the photo.
Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
Slide the left lock (labeled "2") to the left and hold it in place.
Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
The Ribbon Cable must be disconnected here to release the keyboard.
Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
You can now lift and remove the keyboard.
Locate the gray wire on the right.
Detach the white end by gently pulling each socket away from the other.
Locate the screws that are shown in the image.
Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
Locate the 4mm flat-head screw. Remove it using the Phillips 00 Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
