Inleiding
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver. You will not be able to remove the screw from the panel as it is designed to stay in the panel.
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. With your fingers, carefully remove the middle panel by lifting the edge with the indent. With your fingers, carefully remove the middle panel by lifting the edge with the indent.
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  5. Using your fingers, release the tabs on both ends of the RAM. Pull the RAM out. The other RAM is released in the same manner.
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
pfedigan
11 Reputatie
4 handleidingen geschreven
Cal Poly, Team 2-23, Maness Spring 2013 Lid van Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Leden
5 handleidingen geschreven
Één commentaar
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 5
Afgelopen 30 Dagen: 9
Altijd: 1,403
