Ga door naar hoofdinhoud
Toshiba Satellite A105-S4284 Disc Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: stap 2, afbeelding 1 van 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: stap 2, afbeelding 2 van 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 3, afbeelding 2 van 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
  5. Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: stap 5, afbeelding 2 van 2
    • Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
    • Grab the drive and pull it out of the laptop.
Conclusie
pfedigan
11 Reputatie
4 handleidingen geschreven
Cal Poly, Team 2-23, Maness Spring 2013 Lid van Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 834
