Ga door naar hoofdinhoud
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
Wat je nodig hebt
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: stap 1, afbeelding 2 van 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 2, afbeelding 3 van 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): stap 3, afbeelding 1 van 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): stap 3, afbeelding 2 van 2
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: stap 4, afbeelding 3 van 3
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
Conclusie
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Ryan Bortnick
722 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 568
