Ga door naar hoofdinhoud
Toshiba Satellite A105-S4074 Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A105-S4074 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite A105-S4074 Battery Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite A105-S4074 Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
Conclusie
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Ryan Bortnick
722 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 365
