Inleiding
This guide will show you how to remove the current RAM module from this laptop and how to re-install a RAM module. Accessing the RAM in this computer is straightforward and requires minimal minimal dis-assembly.
Wat je nodig hebt
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
