Inleiding
Installing a new optical drive is quite simple, and only requires removing one screw. The difficulty comes from removing the display from the computer, which allows you to then remove the optical drive.
Wat je nodig hebt
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
Stap 6 Display
Voorzichtig: stappen 6-7 komen van een handleiding die in bewerking is.
Turn the laptop over, so that you are now looking at the bottom of the laptop.
Using the Phillips #1 screwdriver remove the fourteen 6mm screws.
Using the Phillips #1 screwdriver remove the three 4mm screws.
Using the #00 Phillips Screwdriver, remove the single screw that holds the optical drive in place.
