Ga door naar hoofdinhoud
Inleiding
This guide will help you take out the battery, and replace it with a new one. Changing the battery is easy and simple.
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A105-S4011 Battery Replacement: stap 2, afbeelding 2 van 2
    • Hold the release switch and pull out the battery towards you.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Lucas Salisbury
73 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-14, Maness Spring 2013 Lid van Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Leden
10 handleidingen geschreven
2 opmerkingen
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - Antwoord
The part number is PSUB2U-00K00P
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,123
