Ga door naar hoofdinhoud
Toshiba Satellite 2435-S255 Battery Replacement
  1. Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: stap 1, afbeelding 1 van 2 Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: stap 1, afbeelding 2 van 2
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Battery Replacement, Remove the Battery: stap 2, afbeelding 1 van 1
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
Conclusie
Jonathan Lancey
1 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-5, Shastany Fall 2014 Lid van UMass Dartmouth, Team 1-5, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G5
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 233
