Inleiding
This repair guide is for replacing a screen that may have been damaged or otherwise no longer functions. Before beginning this guide, make sure you have a Spudger and a Philip's Head 0 screwdriver bit.
To make sure the screen is not properly working and is in need of replacement, refer to this troubleshooting guide
Wat je nodig hebt
Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
Open the laptop and remove the two highlighted screws using a PH 0 screw bit.
