Inleiding
Toshiba Satellite 2430-S255 Hard Drive Replacement. Uses Toshiba Satellite 2430-S255 Optical Disc Drive Replacement as a prerequisite guide.
To make sure the hard drive is not properly working and is in need of replacement, refer to bethis troubleshooting guide
Wat je nodig hebt
Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
Flip your device on its backside.
Slide the latch on the bottom left of the backside all the way to the left
Keep holding the latch in that position and move to the next step.
Locate and unscrew the 4 6mm Phillips Head Screws using a PH 0 Screwdriver bit.
Één andere persoon heeft deze handleiding voltooid.
