Ga door naar hoofdinhoud
Toshiba Satellite 1805-S177 TrackPad Replacement
Wat je nodig hebt
  1. Toshiba Satellite 1805-S177 TrackPad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
  2. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery casing gently out toward yourself, until you hear a clicking sound.
    • The battery should pull out to about 2 inches.
  3. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 3, afbeelding 1 van 1
    • Lift the battery casing out of the laptop.
  4. Toshiba Satellite 1805-S177 TrackPad Replacement, Keyboard: stap 4, afbeelding 1 van 2 Toshiba Satellite 1805-S177 TrackPad Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  5. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite 1805-S177 TrackPad Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite 1805-S177 TrackPad Replacement: stap 5, afbeelding 3 van 3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  6. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 6, afbeelding 1 van 1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  7. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite 1805-S177 TrackPad Replacement: stap 7, afbeelding 2 van 2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
  8. Toshiba Satellite 1805-S177 TrackPad Replacement, TrackPad: stap 8, afbeelding 1 van 1
    • Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
    • This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
  9. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 9, afbeelding 1 van 1
    • Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
  10. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite 1805-S177 TrackPad Replacement: stap 10, afbeelding 2 van 2
    • Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
  11. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite 1805-S177 TrackPad Replacement: stap 11, afbeelding 2 van 2
    • Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
  12. Toshiba Satellite 1805-S177 TrackPad Replacement: stap 12, afbeelding 1 van 1
    • Lift the track pad gently towards you, using your fingers.
Conclusie
Hannah
227 Reputatie
7 handleidingen geschreven
Cal Poly, Team 3-5, Johann Summer 2010 Lid van Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,068
