Ga door naar hoofdinhoud
Toshiba Satellite 1805-S177 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite 1805-S177 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Conclusie
Hannah
227 Reputatie
7 handleidingen geschreven
Cal Poly, Team 3-5, Johann Summer 2010 Lid van Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Leden
24 handleidingen geschreven
Één opmerking
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 4,190
