Ga door naar hoofdinhoud
Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
Wat je nodig hebt
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 3, afbeelding 2 van 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: stap 5, afbeelding 1 van 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: stap 5, afbeelding 2 van 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: stap 5, afbeelding 3 van 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 7, afbeelding 2 van 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 8, afbeelding 3 van 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: stap 9, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: stap 9, afbeelding 2 van 2
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: stap 10, afbeelding 2 van 2
    • Pull upward on the small white ribbon cable to detach from circuit board.
Conclusie
Kiril Lange
943 Reputatie
9 handleidingen geschreven
USF Tampa, Team 3-2, Brown Fall 2014 Lid van USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Leden
27 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 1,416
