Inleiding
This guide gives instructions on how to remove the fuse located on the yellow motherboard of the Toshiba SD-K740 DVD player.
Wat je nodig hebt
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
Één andere persoon heeft deze handleiding voltooid.
