Ga door naar hoofdinhoud
Toshiba SD-K740 Inverter Board Replacement
Wat je nodig hebt
  1. Toshiba SD-K740 Inverter Board Replacement, Top Panel: stap 1, afbeelding 1 van 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Inverter Board Replacement: stap 2, afbeelding 1 van 2 Toshiba SD-K740 Inverter Board Replacement: stap 2, afbeelding 2 van 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Inverter Board Replacement: stap 3, afbeelding 1 van 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Inverter Board Replacement, Front Panel: stap 4, afbeelding 1 van 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Inverter Board Replacement: stap 5, afbeelding 1 van 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Inverter Board Replacement: stap 6, afbeelding 1 van 2 Toshiba SD-K740 Inverter Board Replacement: stap 6, afbeelding 2 van 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Inverter Board Replacement, Inverter Board: stap 7, afbeelding 1 van 1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Inverter Board Replacement: stap 8, afbeelding 1 van 2 Toshiba SD-K740 Inverter Board Replacement: stap 8, afbeelding 2 van 2
    • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
  9. Toshiba SD-K740 Inverter Board Replacement: stap 9, afbeelding 1 van 2 Toshiba SD-K740 Inverter Board Replacement: stap 9, afbeelding 2 van 2
    • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
  10. Toshiba SD-K740 Inverter Board Replacement: stap 10, afbeelding 1 van 1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force cable, it should slide out with minimal force.
  11. Toshiba SD-K740 Inverter Board Replacement: stap 11, afbeelding 1 van 1
    • Pull power cord vertically to detach from the casing.
  12. Toshiba SD-K740 Inverter Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
  13. Toshiba SD-K740 Inverter Board Replacement: stap 13, afbeelding 1 van 1
    • Push the inverter board forward and to the left to remove from the holding ledges.
  14. Toshiba SD-K740 Inverter Board Replacement: stap 14, afbeelding 1 van 2 Toshiba SD-K740 Inverter Board Replacement: stap 14, afbeelding 2 van 2
    • Lift the inverter board from the back end and pull toward you to complete removal.
Conclusie
Joe Murphy
542 Reputatie
5 handleidingen geschreven
Cal Poly, Team 1-16, Amido Winter 2011 Lid van Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,098
