Ga door naar hoofdinhoud
Toshiba SD-K740 Front Panel Replacement
Wat je nodig hebt
  1. Toshiba SD-K740 Front Panel Replacement, Top Panel: stap 1, afbeelding 1 van 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Panel Replacement: stap 2, afbeelding 1 van 2 Toshiba SD-K740 Front Panel Replacement: stap 2, afbeelding 2 van 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Panel Replacement, Front Panel: stap 4, afbeelding 1 van 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Panel Replacement: stap 5, afbeelding 1 van 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Panel Replacement: stap 6, afbeelding 1 van 2 Toshiba SD-K740 Front Panel Replacement: stap 6, afbeelding 2 van 2
    • Grasp the front panel and pull forward to your right to remove it.
Conclusie
Joe Murphy
542 Reputatie
5 handleidingen geschreven
Cal Poly, Team 1-16, Amido Winter 2011 Lid van Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 502
