Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Lift and push away the two tabs located in the middle of the player.
Grasp the front panel and pull forward to your right to remove it.
On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
Once the peg is free from the left restraint, carefully remove the left part of the flap.
Carefully remove the right peg from the restraint.
Remove the spring from the end of the right peg by pulling the door away from the spring.
