Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide gives instructions on how to remove the disc drive front flap of the Toshiba SD-K740 DVD player.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure the DVD player is unplugged before beginning.
    • Make sure the DVD player is unplugged before beginning.
    • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
  2. Turn the DVD player on its side. Remove the .303 inch screw.
    • Turn the DVD player on its side.
    • Remove the .303 inch screw.
    • Now flip the DVD player onto its other side.
    • Remove the .303 inch screw from this side.
  3. Flip the DVD player over onto its front face.
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Flip the DVD player so its top is sitting on your working surface.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away each of the two tabs located in the middle of the player.
    • The front panel will not come off during this step, so do not force it.
  5. Flip the DVD player on its side.
    • Flip the DVD player on its side.
    • Lift and slide forward a single tab on the side.
  6. Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
    • Grasp the front panel and pull forward and to your right to remove.
  7. On back side of front panel very carefully apply pressure to the left hand side of the flap hinge. There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
Conclusie
John Lokker
319 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-16, Amido Winter 2011 Lid van Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 1,272
