Inleiding
This guide will demonstrate how to change the RAM (random access memory) in a Toshiba Qosmio X775-3DV80. RAM is used as storage for temporary data. Browsers, media players, and applications are just some of the programs that utilize the quick access
RAM to function.
Computers with more RAM can run a greater amount of programs simultaneously. As such, installing larger RAM sticks is one of the best and simplest methods for upgrading your laptop. Whether you’re upgrading or replacing faulty sticks, this guide can help.
For additional information on this laptop’s RAM, please refer to the manual found here:
Toshiba Qosmio X775-3DV80 Manual
Before starting, please make sure to turn off and unplug the computer. The RAM may be hot if the computer has been running recently.
Wat je nodig hebt
Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
