Inleiding
This repair guide will give you the steps to follow to replace the keyboard of your device.
Wat je nodig hebt
Remove the white Bundled Cable Connector by gently pulling it out of the socket. Follow the guide here.
Gereedschap gebruikt in deze stap:iFixit Opening Tool$1.99
Flip the device over to access the keyboard.
Insert the Opening Tool into the crevice on one side of keyboard frame.
Pry off the keyboard using the tool.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Ordering the parts for my wife’s Toshiba shortly. It has been an excellent machine but the keyboard keys have worn off. Seems like a very straight forward process. The question that I have is what do I use to hold the keyboard back in place?
Thanks for the directions. George
Only one key gets off the keyboard (down cursor) I’ve got the key and the rounded rubber that fits into the mechanism, most of the time it works but when I press continusly it gets off.
Is there a way to fix it without changing the whole keyboard?
