Inleiding
The Wi-Fi card in the Toshiba Portege R705-P35 is used to sustain a wireless internet connection. The card may become out of date and need to be replaced. The card can be accessed by removing the backplate. It is located next to the RAM cards. Make sure to pay attention when reattaching the black and white wires as placement is important. Also, insert the new board at a 45-degree angle before screwing it back in.
Wat je nodig hebt
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
Use your fingers to disconnect the white and black cords from the Wi-Fi card.
