Inleiding
The Toshiba Portege R705-P35 has a built-in fan that is used to actively cool off the electrical components that make up the device. The fan is located in the lower right corner of the device directly under the backplate. When replacing, be sure to completely plug in the white wire plug to ensure a connection to the motherboard.
Wat je nodig hebt
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
Remove the two 4 mm screws that join the fan to the device using a Phillips #00 screwdriver.
