Inleiding
The Toshiba Portege R705-P35 has a DVD disc drive to load and play video files. If your DVD won't play, even after cleaning, the DVD drive may need to be replaced using this guide. The drive is located on the left side of the device when it is open and in the standard position. The drive can be easily accessed by removing the back panel. Be sure to save all the screws and the metal plate for easy reinstallation. Also when plugging in the ribbon cable, make sure it's completely inserted.
Wat je nodig hebt
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
Use an opening tool to detach the hard drive connector from the DVD drive.
