Ga door naar hoofdinhoud
Toshiba Portege R705-P35 DVD Drive Replacement
Wat je nodig hebt
  1. Toshiba Portege R705-P35 DVD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 DVD Drive Replacement: stap 2, afbeelding 1 van 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 DVD Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Portege R705-P35 DVD Drive Replacement: stap 3, afbeelding 2 van 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: stap 4, afbeelding 1 van 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: stap 4, afbeelding 2 van 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: stap 4, afbeelding 3 van 3
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 DVD Drive Replacement, Hard Drive Plate: stap 5, afbeelding 1 van 1
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 DVD Drive Replacement: stap 6, afbeelding 1 van 2 Toshiba Portege R705-P35 DVD Drive Replacement: stap 6, afbeelding 2 van 2
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 DVD Drive Replacement, Back Plate: stap 7, afbeelding 1 van 1
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 DVD Drive Replacement: stap 8, afbeelding 1 van 2 Toshiba Portege R705-P35 DVD Drive Replacement: stap 8, afbeelding 2 van 2
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 DVD Drive Replacement: stap 9, afbeelding 1 van 1
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 DVD Drive Replacement: stap 10, afbeelding 1 van 2 Toshiba Portege R705-P35 DVD Drive Replacement: stap 10, afbeelding 2 van 2
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: stap 11, afbeelding 1 van 2 Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: stap 11, afbeelding 2 van 2
    • Use an opening tool to detach the hard drive connector from the DVD drive.
  12. Toshiba Portege R705-P35 DVD Drive Replacement: stap 12, afbeelding 1 van 3 Toshiba Portege R705-P35 DVD Drive Replacement: stap 12, afbeelding 2 van 3 Toshiba Portege R705-P35 DVD Drive Replacement: stap 12, afbeelding 3 van 3
    • Remove the two 4 mm screws using a Phillips #00 screwdriver.
    • Remove the one 3 mm screw using a Phillips #00 screwdriver.
    • Remove the silver bracket that comes loose.
  13. Toshiba Portege R705-P35 DVD Drive Replacement: stap 13, afbeelding 1 van 3 Toshiba Portege R705-P35 DVD Drive Replacement: stap 13, afbeelding 2 van 3 Toshiba Portege R705-P35 DVD Drive Replacement: stap 13, afbeelding 3 van 3
    • Pull on the orange bar with your fingers to detach it from the DVD drive.
    • Pull out and remove the DVD drive from the laptop.
Conclusie
Kathryn Hockenbury
833 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 1-4, Botvin Spring 2022 Lid van UMass Dartmouth, Team 1-4, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G4
3 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 185
