Inleiding
This will show you how to remove the battery from the laptop.
Gereedschap
Geen gereedschap nodig.
  1. Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
Conclusie
JRJones
121 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-19, Maness Spring 2013 Lid van Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 119
