Ga door naar hoofdinhoud
Toshiba Portege M300 Wireless Card Replacement
Wat je nodig hebt
  1. Toshiba Portege M300 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Wireless Card Replacement: stap 2, afbeelding 1 van 2 Toshiba Portege M300 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Wireless Card Replacement: stap 3, afbeelding 1 van 2 Toshiba Portege M300 Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 2 van 3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 3 van 3
    • Turn the computer onto the back.
    • Remove the Phillips #0 screw that secures the cover to the rest of the device.
    • One 5.1 mm coarse thread screw.
    • Pull the cover forward to release it.
  5. Toshiba Portege M300 Wireless Card Replacement: stap 5, afbeelding 1 van 3 Toshiba Portege M300 Wireless Card Replacement: stap 5, afbeelding 2 van 3 Toshiba Portege M300 Wireless Card Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
    • Two 4.0 mm coarse thread screws.
    • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  6. Toshiba Portege M300 Wireless Card Replacement: stap 6, afbeelding 1 van 2 Toshiba Portege M300 Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
Conclusie
Alison Wendt
135 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-51, Johann Spring 2013 Lid van Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 846
