Ga door naar hoofdinhoud
Toshiba Portege M300 LCD Replacement
Wat je nodig hebt
  1. Toshiba Portege M300 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: stap 2, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 2, afbeelding 2 van 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: stap 3, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: stap 4, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement, LCD: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: stap 5, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 5, afbeelding 2 van 2
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: stap 6, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 6, afbeelding 2 van 2
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: stap 7, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: stap 8, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: stap 9, afbeelding 1 van 1
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: stap 10, afbeelding 1 van 2 Toshiba Portege M300 LCD Replacement: stap 10, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alison Wendt
135 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-51, Johann Spring 2013 Lid van Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 1,024
