Ga door naar hoofdinhoud
Toshiba Portege 3110CT Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Portege 3110CT Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Lift the keyboard up and slide it downwards and out.
Conclusie
Spencer Gamble
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 6-4, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 319
