Ga door naar hoofdinhoud
Toshiba NB305 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba NB305 Keyboard  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: stap 2, afbeelding 1 van 1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: stap 3, afbeelding 1 van 2 Toshiba NB305 Keyboard  Replacement: stap 3, afbeelding 2 van 2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: stap 4, afbeelding 1 van 2 Toshiba NB305 Keyboard  Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: stap 5, afbeelding 1 van 3 Toshiba NB305 Keyboard  Replacement: stap 5, afbeelding 2 van 3 Toshiba NB305 Keyboard  Replacement: stap 5, afbeelding 3 van 3
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: stap 6, afbeelding 1 van 2 Toshiba NB305 Keyboard  Replacement: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: stap 8, afbeelding 1 van 2 Toshiba NB305 Keyboard  Replacement: stap 8, afbeelding 2 van 2
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nuri Chung
368 Reputatie
3 handleidingen geschreven
USF Tampa, Team 5-5, Lacy Fall 2016 Lid van USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 683
