Ga door naar hoofdinhoud
Toshiba NB255-N250 Memory Replacement
Wat je nodig hebt
  1. Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: stap 1, afbeelding 1 van 2 Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: stap 1, afbeelding 2 van 2
    • Before starting any repairs, make sure to power off your device.
    • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
  2. Toshiba NB255-N250 Memory Replacement, Remove the Battery: stap 2, afbeelding 1 van 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: stap 2, afbeelding 2 van 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: stap 2, afbeelding 3 van 3
    • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
  3. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel Screw: stap 3, afbeelding 1 van 1
    • Remove the PH1 screw from the memory access panel.
    • Unlike many other access cover screws on laptops, this screw is not captive.
  4. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel: stap 4, afbeelding 1 van 1
    • Use a Metal Spudger or other opening tool to remove the memory access panel.
  5. Toshiba NB255-N250 Memory Replacement, Remove Old Memory: stap 5, afbeelding 1 van 2 Toshiba NB255-N250 Memory Replacement, Remove Old Memory: stap 5, afbeelding 2 van 2
    • Remove the memory by moving the tabs on the left and right away from the ram.
    • When fully opened, the memory will pop up at a 45 degree angle. Pull the memory straight out by the sides and away from the system.
Conclusie
Charles Myrick
270 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 485
