Inleiding
Removal and replacement of the RAM module
Wat je nodig hebt
Save your work.
Turn off the computer. The LED Power must not light up anymore.
Close the screen and place the computer face down as shown in the picture.
Slide the safety latch (on the left side of the picture) to the unlocked position (to the left) to activate the release.
Slide the battery release (pictured on the right) to the right side and hold it to release the battery and remove the battery from the back of the computer.
Remove the screw with a Phillips # 1 screwdriver securing the memory module cover. To remove the cover, use the recess below the screw and lift the cover upwards.
Now you see the RAM module in its socket. Carefully push the two metal clips outwards until the module is free and jumps upwards by about 30 degrees.
Remove the RAM module by grasping it at the corners and pulling it to the right out of the socket.
Place the RAM module securely on the work surface.
Repeat the steps in reverse order to reassemble your device.
Met dank aan deze vertalers:
100%
Corey Meyer helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
