Using a spudger, gently pry the screen bezel to the condition of the photograph.
For this procedure, it is not necessary to completely removal screen bezel so in order to reduce work, bezel is just partially removed.
Using pliers, gently remove the electrical connection to the webcam by pulling the plug to the right (per orientation of the photo).
Allow the removed wire to hang in place but make note of alignment with respect to webcam.
This step is performed while holding down the bezel which is only partially detached.
Position the new webcam in the old webcam's position. The webcam must be carefully aligned in order to function properly with the bezel in place. Align the hole of the webcam assembly over the cylinder of the webcam stabilizer.
Reconnect the electrical connection.
Gently press the front bezel back into its original position.
Using the bit driver and Phillips #0 bit, drive the two bezel retaining screws in to place.
Cover the screws with the small covers with tweezers.
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Enkele stap
Volledige handleiding
Klein - 600px
Middelgroot - 800px
Groot - 1200px
Voorbeeld
