1. Start by first removing the battery. Move the first release switch to the right position.
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
  3. While holding the top of the netbook, flip the netbook over. While holding the top of the netbook, flip the netbook over.
    • While holding the top of the netbook, flip the netbook over.
  4. Carefully lift off the power bar assembly for access to the button and receiver. Carefully lift off the power bar assembly for access to the button and receiver.
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  6. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  7. Reach under the keyboard and disconnect the electrical connection. Lift the keyboard assembly out and away from the netbook.
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the keyboard assembly out and away from the netbook.
  8. Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool. Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
    • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
  9. Remove this electrical connection with tweezers. Use a spudger to gently pry the bezel from retaining clips.
    • Remove this electrical connection with tweezers.
    • Use a spudger to gently pry the bezel from retaining clips.
    • This will allow the keyboard bezel to lift off of the body.
  10. Use tweezers to remove the electrical connection to the old speaker assembly.
    • Use tweezers to remove the electrical connection to the old speaker assembly.
  11. Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly. Lift out the old speaker assembly.
    • Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly.
    • Lift out the old speaker assembly.
Conclusie
Mason McCaskill
943 Reputatie
9 handleidingen geschreven
Clemson, Team 14-2, Benson Fall 2013 Lid van Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 338
