Ga door naar hoofdinhoud
Toshiba NB205 N330PK Key Cleaning
Wat je nodig hebt
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: stap 1, afbeelding 1 van 1
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: stap 2, afbeelding 1 van 2 Toshiba NB205 N330PK Key Cleaning: stap 2, afbeelding 2 van 2
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: stap 3, afbeelding 1 van 1
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
Conclusie
This is a complete guide to removing a key and cleaning the area before replacement.
Mason McCaskill
1.000 Reputatie
9 handleidingen geschreven
Clemson, Team 14-2, Benson Fall 2013 Lid van Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Leden
27 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 479
