Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back cover.
Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
Remove any black tape from the device.
Keep the tape, you will need to put it back on when you are done.
Unscrew the battery from the device.
The device has 5 screws to remove, keep the screws.
Gently flip the black lever up and unplug data cables.
Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
Remove the rubber device from the old screen.
Make sure you keep the rubber device to be install into the new screen.
Repeat other steps in reverse to install replacement screen.
