Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back cover.
Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
Remove any black tape from the device.
Keep the tape, you will need to put it back on when you are done.
Unscrew the battery from the device.
The device has 5 screws to remove, keep the screws.
Remove the the remaining 3 screws to unfasten circuit board. Keep the screws.
The screen is connected to the circuit board by 2 “Data Cables” (orange ribbons). Data cables include 3 working components, data cables, the white harness plug, and the black lever.
Gently flip the black cover up and unplug data cables.
Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
Flip the circuit board over, the camera is the small black square with the circle in the middle.
Gently unplug the camera from the circuit board and plug the new camera back into the socket. Repeat steps in reverse order to reasemble device.
Één andere persoon heeft deze handleiding voltooid.
